What's new
License key:
The free key expires August 15, 2022.
RadioBOSS 6.2 beta:
x86 https://dl.djsoft.net/beta/radioboss_beta_6.2.0.4.exe (7/13/2022, 31MB)
x64 https://dl.djsoft.net/beta/radioboss_beta_6.2.0.4_x64.exe (7/13/2022, 35MB)
- Scheduled events: multiple start times can be specified for an event
- Scheduled events: event duration limit can be specified
- Command execution on startup: allows specifying commands to be executed upon RadioBOSS start
- VU meter source can be seleced (Audio Mix or one of the Inputs)
- File type bed: multiple bed track can be specified
- File type option: do not update playcount and last played tags
- File type column added to the playlist
- Mute playlist when prelistening in Track Tool, Segue Editor and Music Library
- AUX playlist: option added to attenuate the main playlist while AUX is playing
- Relay: allows specifying playlist volume when the relay is connected (previously the playlist was always muted)
- Teaser: added minimal rating option to filter music tracks
- Voice track recorder: MIC DSP is applied to recorded voice tracks
- Added temperature variables for track title format (%temp, %temp_tom, etc)
- Option added: use the Last Played tag when checking for repeat protection in Track List
- Select what title to show in Last Played/Now Playiung/Upcoming bars (playlist title or broadcast title)
- Improved time display in event list: shows custom hours and additional start time
- Advanced option added: broadcasting state after RadioBOSS restart
- Advanced option added: sweeper - minimum time to sweep
- Improved quality of radio logo display in the main window
- Increased intro countdown bar size
- Select double click action for Search and File Explorer windows
- Tool bar: certain items can be hidden (View->Toolbar menu)
- Broadcasting stats: individual chart for each encoder (for last hour only)
- makelibrary command allows adding individual files to the library
- Adjustable color for weather display in the main window
- Added menu command to delete a track from disk
- Allows using up to five sweepers (previously it was limited to three)
- Print feature prints only filtered tracks when the filter is enabled
- Improved batch track process user interface
- Added import/export of the related artists list
- Index number can be enabled in the rotation list (right click menu)
- Fixed: separate artists repeat protection didn't work for some single character separators
- %len and %playcount track title format variables had wrong values when Track List was playing
- Segue Editor occasional incorrect initial fade in/out position
- Broadcasting statistics window flicker removed when using custom themes
- Next track incorrectly selected sometimes when playing track was removed
- Next track incorrectly sometimes evaluated incorrectly when playling last scheduled track and Shuffle enabled
- Other bugs fixed, minor improvements
License key:
RadioBOSS 6.2 beta:
