RadioBOSS 7.0.1.9 freezes
JeanXeb
I have just upgraded the studio to the latest version of radioboss 7.0.1.9 (x86) (Windows Server 22) and since then I have had the studio freeze regularly.
The first major freeze occurred when I simply opened the Ads Sheduler.
The second freeze when I opened a song from the studio with the tracktool.
I would like to point out that I have not touched anything on the machine since or touched the radioboss settings....
Best regards,
Captures
Please click (in RadioBOSS) Help->Contact support->Send bug reports, we'll check what's going on there.
Hi Hi Jean mine as ok. we upgraded to more ram before doing mine so running 64GB Ram. IT all opened with tab open for add schedules. Switchin between tabs gave no error to me
Thank you HMMMM for your comment I added 1GB of ram but the problem is still there...
djsoft were you able to find the source with my report ?
The bug reports are now being checked. Do you have a crash when you change the style, or it happens every time when you simply launch Track Tool?
i only have 22 GB of RAM and no problems at all
Win 10 pro ( Not a Server )
we have discovered a bug in the browser
If you copy a url where there are also numbers in the address line everything is ok
but if you want to enter the same address by hand, the numbers are not accepted
RadioBoss 7.0.3.1 keeps freezing, no response
Hello, my RadioBoss 7.0.3.1 constantly freezes when sending, no feedback which is annoying, what could be the problem? Otherwise RadioBoss 7.0.3.1 is a great thing, only this problem with the feedback that the RadioBoss keeps giving me of my shipment
Butt am not running scheduled playlists on it but some scheduler bits and it's not freezing me perhaps its your connection to the stream
Please click Help->Contact Support->Send bug reports. We'll check what could be wrong there.
If you use any 3rd party plugins, please try disabling them.
Hello, my RadioBoss 7.0.5.0 constantly freezes then when I do the help it said no bug reports found. I need some help with this. Thank You
