RadioBOSS Advanced (7.0.1.9): Sweepers Intro - Auto Intro..!
I have a series of playlists that I need to activate but I always see repeated artists...!
Are all those playlists created by playlist generator? If so, it's highly recommended to create them all in one go, using the "create multiple playlists" feature: https://manual.djsoft.net/radioboss/en/generating-multiple-playlists.htm
This way, all playlists will share the same repeat protection buffer, ensuring there are no cross-playlist repeats.
What's the point of not repeating tracks in the RB window if it doesn't work...?
There's no repeat protection for the playlist window as such, playlist window plays whatever's loaded into it. Repeats either handles in advance (e.g. when you create playlist using the Playlist Generator, or manually) or handled in-place when you use the Track List feature.
Forgive me if I reply late. Thank you for the reply.
Yes. They were created "individually" with Playlist Generator Pro.
Unfortunately I read the answer after creating them.
So, can I still follow your advice now that I have created all the Presets and Playlists individually?
How can I do?
I take advantage of this post.
Event - Say Time setting.
1. I inserted a jingle that acts as an intro (and it's fine)
2. I inserted the Say Time, but unfortunately, it "cuts the ending".
(I tried inserting an effect after the Say Time, but it still cuts it.)
What do I have to do for it to play completely?
Thank you.
Ok!
Thank you.
Resolved..!
Settings - Preferences - Fading
Presets are OK, but you may should recreate the playlist using the Playlist Generator, using the Create Multiple Playlists option.
