RadioDave
I hope this isn't a feature that already exists
I have a simple stream that I use to entertain my family and friends with old pop hits and trivia. I?ve been focusing on getting the best sound from the stream than I can. I am using Stereo Tool to provide custom processing.
I have found that getting the very best sound requires that I introduce latency in the signal. This latency precludes hearing the output while speaking on the microphone without causing insanity. Therefore, I manually mute the speakers locally when I?m speaking on the microphone.
My feature request is ?Local Mute? when the microphone button is pressed. This would mute the local speakers when the microphone button is pressed, while allowing the stream to broadcast. While I would not hear the stream while the microphone was on, I wouldn?t have to manually mute the speakers each time I wanted to speak.
RadioBOSS 4.5.3.824
Microphone Details
?MIC? button
WASAPI
Device: Mic in at rear panel
Music level: 0
Fade in / out: 0
DirectSound Input prebuf: 0.002
WASAPI Input buffer: 0.021
ASIO Input buffer (0=default)
Windows 7 Ultimate 64-bit
8G RAM available
RadioBOSS using 63MB
Average CPU loading: 12% with priority set to High (~38% on a one of four cores)
RadioBOSS 4.5.3.824
Microphone Details
?MIC? button
WASAPI
Music level: 0
Fade in / out: 0
8G RAM available
