jharris171185
I have several feature requests and improvements I would like to ask for. Some of these are for desktop, some are for cloud. I will make sure I mention which one each applies to.
1. Desktop: Crossfading options could be labeled better for screen reader users. I have yet to figure out what does what for some of those options. I have a lot of songs that are fading way to early, but can't figure out what to adjust.
2. Desktop: Using nvda screen reader, under options for hot keys, there are lots of unlabeled checkboxes, so hard to tell what each box is supposed to toggle. It might also be helpfull to update the help system with a list of what all the default hot keys are. Found the information on the subject to be rather limitted.
3. Cloud: Make equalizer and compressor accessible, or at the very least, allow us to apply a preset like in the desktop version. Then we can at least mess around with presets until we find one that is to our liking.
4. Cloud: All more than 1 folder per file type. This would be handy for things like programs, where we never want any fading. Instead of creating a filetype for each and every one, we could just select multiple folders.
5. Cloud: Enable agregated stats for all encoders. So, if I'm broadcasting to a shoutcast server, have those stats also combine with stats from the default radioboss.fm stream. It would also be nice if this could be made to work with Zeno, so those stats would also show up with everything else. A good way to have all your listener stats in one spot, and not have to pull up multiple control panels for multiple streaming services to manually add up all the stats.
6. Cloud: Would really love to see voice tracking.
7. A way to sync playlists between desktop and cloud, so that, if a song was recently played on cloud, and we are setting up a playlist for desktop, it won't set songs that already played within the separation rules set on cloud, or if we try to manually insert a song that would violate those rules, give us a prompt saying that song violates separation rules, and ask if we really want to insert it. It would require keeping things synced somehow between cloud and desktop.
8. Will we ever see Radioboss for mac?
