Track duration missing in Music Library
Danijel
After udate to 5.6.2.0. when I add new commercial, or music track into Music library it does not show "duration" of file. For old tracks it shows, but not for new. In playlist is ok.
Also, now I have two Radio Boss tabs in taskbar of my xp...
In the Music Library, please click Tools->Preferences, and make sure that "Calculate duration upon adding files" is checked.
Also click Tools->Calculate duration to calculate duration for tracks that are without duration.
It could be because you installed and started it two times. Try closing both and start it again.
"Calculate duration upon adding files" is checked, and it was checked, but I still have to calculate it manually, by pressing "calculate duration"....
Also, I still have two tabs, and it is not installed twice, one is "RadioBoss" an the other is RadioBoss Standard (5.6.2.0). The other one shows up when I change any of settings...., and it stays there untill I restart computer.
And, one more thing, where can I find "Remove nonexistent files", now there is only "Show..."?
The bug does not seem to reproduce here. The duration is displayed once tracks are added to the list. Considering other bug (two tabs), I suggest you to download the software again: http://dl.djsoft.net/radioboss_setup.exe and reinstall.
The "remove nonexistent files" feature was removed, instead, it shows nonexistent tracks in the playlist (with red outline).
