Web browser in RadioBOSS
Web browser tab in RadioBOSS uses Edge as a rendering engine. Typically, no additional configuration is required and the web browser works out of the box.
If, for some reason, the browser doesn't work, please install WebView2 Runtime:
Use the "Evergreen Standalone Installer" option, select x86 or x64 - must be the same architecture as your RadioBOSS installation. You can check RadioBOSS architecture by clicking Help->About, if it says at the top "RadioBOSS a.b.c.d x64" then you have a 64-bit version, otherwise it's x86.
If you do the two steps listed in the first message, RadioBOSS will use Edge as browsing engine automatically.
It worked for me with "RadioBOSS_ChromeWebBrowser" but after clicking the above link, Edge automatically installed without asking location.
Honestly not working for me even after uninstalling explorer and re-installing edge.
From your screenshot it seems that it actually works. The web address you input is not valid. Try https://gmail.com instead. The web browser in RadioBOSS is very simple, it won't add ".com" to the addresses automatically like the normal web browsers do :)
Thanks, it worked but after entering my email address, an error message appeared, see screenshot attached.
