hro_sebastian
Hi Dmitry @djsoft ,
this is a mix between questions and suggestions, that's why I created this thread in the support section.
is it possible to use key combinations (e. g. "CTRL" + "SHIFT" + "G"), not only one key?
Also I miss a shortcut for "start/stop broadcasting" and "start/stop stream archive" (not pause). Or an option to start/stop stream archive automatically when broadcasting starts/stops.
All these shortcuts should be available "system wide", so that these works even if RadioBOSS is in the background. Maybe as an option?
Further it would be nice to disable that "stop broadcasting" dialogue. Is that possible?
I wish there would be a way to custimze the hotkeys completely, not only pressing CTRL/ALT, release and press another key.
How to remove these note icons from playlists?
The defference between played and not played doesn't make any sense (to me), because I use songs multiple times. I don't create a new playlist every time , I rework the existing, so songs are marked as played even though they aren't.
Another suggestion: Maybe you can make the function "already played" deactivatable?!
Further it would be fantastic to add a function to insert a Hook from a single song by short time without using the complex teaser function.
(E. g. right click on a playlist entry and "insert hook / teaser").
Regards
Sebastian
Regards
Sebastian
