radiomanpasand
When I press play button on top right hand corner of RadioBoss cloud Control panel.. it does not play
and it’s stuck on repeating same 1 sec of song .. Please Help!! Thanks
That worksPlease try restarting player and server from the System area. Does it play correctly if you play the stream using desktop player?
Exactly I’m having the same problem with my RB Cloud player. It says “Error occurred. Unable to play stream. Restart in 4 seconds”my streaming radio just stopped and saying unable to play stream i dont understand
P.S thanks for the updateCertificate expiration is causing this....
Sorry, it’s not working stillWe have fixed this. For some odd reason the certificate was reverted to the old one. Sorry for the inconvenience it had caused.
You haven't it's still not working you clearly haven't checked this properly?We have fixed this. For some odd reason the certificate was reverted to the old one. Sorry for the inconvenience it had caused.
it’s working now. All good.We have fixed this. For some odd reason the certificate was reverted to the old one. Sorry for the inconvenience it had caused.
It was cached so it can take some time for a cache to renew. Our monitoring shows now that all streams are now accessible and use the up to date certificate. We have rebuilt the certificate updating process to prevent this problem in the future.Still unable to access, I guess this could take some time to filter through?
