Regarding editing Teasers
box26609
Everytime I edit an existing teaser and try to save it, a blank slot pops up for me to enter a new name to save it as. Is there a way to make it so that everytime I press the save button the current teaser name pops up by default so I can save it as is, while also giving me the option to enter a new name if I so choose (as is the case when editing Playlists, for example).
I am finding it challenging to have to remember to type afresh the exact teaser name for the one I'm currently editing, and there is potential to type the name wrongly which can effect playlist generation as these teasers are sometimes scheduled from the Playlist Generator within categories.
The Teaser doesn't have a Name field, can you please specify where do you enter this name?
Sorry I'm referring to the teaser Presets
It doesn't keep the name of the loaded preset, so once you click Preset, Load, and select a preset, it loads the preset and that's it. It's not really designed to edit the presets frequently.
Also, every time I try to delete a teaser preset I'm met with an error that prevents me from deleting the preset. How may I resolve the issue.
Can you please specify what does the error message say and what RadioBOSS version you use?
Does it show this error message when deleting any preset or only for a specific one?
This does not reproduce here. Are you able to save new presets? Please also check that you use the latest RadioBOSS.
