Rating songs
Onofre
Hi, I am a registered user of radio boss and I'm using Music Library to use playlist generator properly i'm doing a lot of work choosing songs an put the ratings but the rating is not saved in the tag of the songs, it does for name artist but not for the rating is there any way to write in the tag of the song ?, maybe some day I'll change the computer and I don't want to repeat the job, anyway if some track has the rating for example 3 stars Music library don't import that field, normally I use mp3 tag to sort my tracks and then I import to music library but the ratings are not imported. Any suggestion please.
I'm not so advanced in this items but normally I use mp3 tag to organise the files and would be interesting that music library will import the BPM and Rating if it is recorded in the file in case of catastrofic failure of computer if I have a copy oif the files on another hd that will be more easy to recover the information in another computer if the filters are used and will be interesting not to analice again all the files.
If you don't want to use a database, there are options to store the additional info in APEv2 tag or in a separate file. Please read the article I have linked above.
I've read it but for me it's so fleeting.
It offers several storage options so depending on your needs you choose one. If you want all additional information be available when you copy the music folder, and don't want to rely on databases, you can choose APEv2 or file options.
