QUESTION ABOUT AUTO INTRO AUDIO EXTENSION
RADIECITA
I WOULD LIKE TO KNOW IF THE AUTO INTRO OPTION HAS ANY TIME LIMITATION REGARDING THE DURATION OF THE AUDIO THAT IS USED, BECAUSE IT HAPPENS TO ME THAT MANY TIMES IT CUT OFF THE AUDIO WITHOUT FINISHING THE PLAYBACK, I SEARCHED IN THE OPTIONS BUT I CAN'T FIND HOW TO MODIFY THIS, SO THAT IT ALLOWS A LITTLE LONGER AUDIO, EVEN THOUGH IT WOULD NOT BE MORE THAN 40 OR 50 SECONDS, THANK YOU VERY MUCH FOR THE RESPONSE
There are no length limitations for the auto intro track. How much does it cut from a track and what is the track duration?
I AM USING VERSION 7.1 BETA FROM RADIOBOSS. THE RECORDING PLAYS ONLY THE TITLE AND ARTIST OF EACH SONG IN THE AUTOINTRO. SO, THE DURATION OF THAT RECORDING NEVER TAKES MORE 10 SECONDS. I USED THOSE SAME RECORDINGS WITH THE SWEEPER KEYS PLAYING THEM MANUALLY OVER THE SONG AND THEY PLAY WITHOUT PROBLEMS BUT I TRIED PLAYING THEM OVER DIFFERENT BITS OF THE SONG AND IN THE INTRO AND OUTRO WITH THE AUTOINTRO FEATURE AND I ALWAYS SEE THE SAME PROBLEM. THE RECORDING STOPS PLAYING AUTOMATICALLY AT AROUND 5 SECONDS LONG. I HAVE CHECKED ALL THE SETTING OPTIONS IN THE PROGRAMME BUT I CAN´T FIND ANY THAT SAYS THAT AUTOINTRO SHOULD HAVE A LIMITED LENGTH.
THANK YOU IN ADVANCE FOR YOUR ANSWER.
CARLOS FROM BUENOS AIRES
P.S. DO YOU THINK I SHOULD TRY A DIFFERENT VERSION OF RADIOBOSS?
Please ensure that you use the latest beta version (7.1.0.3) and if it still doesn't work there, send us one of the intro files you use so we can test it here. Please also include a screenshot of the rule that you use.
correct, the version is beta 7.1, I send you one of the audios that failed and the necessary screenshots
This is one of the audios that cuts is generated with the notification that radioboss sends when the title changes, it does so with an external program that takes the "artist" "title" and converts it into audio, the file is generated correctly, I changed the format to mp3 and there are no changes, By pressing the foot button with the same file manually it is played perfectly in its entire length whatever it was.The filter options in autointro are not marked.
If you could find the problem it would be very good, because we use this system so that on the song an announcer automatically announces the artist and the title, and everything happens perfectly in the time that is set and with the audio generated except that when the extension exceeds a certain time, it is truncated, thank you for the support and move forward with the project,.
Radioboss is one of the most versatile automation systems, easy to use and program and with excellent quality in its encoders.
  • titulo_combined.rar
    titulo_combined.rar
ok I downloaded and I am testing the recommended version, I will give you news when I have done some tests, thank you very much greetings to the entire development team
Carlos from Buenos Aires(y)
After trying the recommended versions and some previous ones in 64 and 32 bit, the conclusion is that the autointro only works well if you cut the title and the artist regardless of their length, with the option to "end in the fade in" any option that is used based on seconds of time, whatever those seconds were, in some cases it cuts the entire recording, I don't know if there is any solution to this problem, or if it is the way in which radioboss loads that recording. Up to this conclusion we reached there is no solution. to do with the version, and there is no way to set the option for time, because it randomly cuts it, if there is any option or possible modification I will stay tuned, thank you for your help
Currently we can't confirm those problems with Auto Intro, it works as intended. Are you sure that the auto intro tracks you use are not damaged or something?
The audio sample that I sent you is an example that they are generated perfectly, and that the artist and title are heard without cuts, in addition the same recordings that are heard cut off when the autointro is set to a location in the playback per seconds option, it is cut, that same recording is played manually with the "sweeper" buttons or choosing the end option in the "fade in" and in those cases there is no clipping of the recording, I tried programming the recording in different seconds within of the music track and the same thing always happens, after a certain number of seconds of audio, it cuts off and does not complete the playback, for now the 2 options that work correctly are placing the recording in the "intro" but that means performing the manual task of placing an intro in each musical track and our radio manages a music database of 4000 songs, an almost impossible task unless there was some way to do it automatically, or as we are using now that "finalize in the fade in" I am a beta tester of the last one version and that is why I present these details to you, my first idea was that there was some limitation in the audio extension of the auto intro, which was ruled out, well it is just for you to think about, greetings from Buenos Aires.
Sorry, this text in English is generated with Google Translate, because my English is very bad, so if there is any error, please forgive me.
I tried with version 7.1.0.3 and I have version 7.0.8.0 running the 2 64bit versions and they have exactly the same problem
I'm going to try the version you recommend, I'll tell you, thank you very much, greetings from Buenos Aires
Today 7.1.0.5 was released, so I suggest to try that.
