Cart Wall "Stop All" and "Touch Screen compatible"
Add:
1. Stop all action
2. Page button
3. Touch Screen compatible
4. Open pages with touch and stop all
Look at the attachment
1. There's an option (right-click on a cart wall tab) - "Play only one cart at a time". If you activate it, starting a cart stops all other playing carts automatically.
2. Pages already exist - you can create as many cart wall tabs as needed.
3, 4. It it already compatible with touch screens.
1. I'm talking stop all cartwall at once
2. The pages exist, only they are small to use as a touch screen
That is to increase the button of the pages to use in the touch and a button to stop all the cartwall at once. For example if I have played several cartwheels and I want to stop all there, it was just a click of a button. And I want to flip pages with the touch quickly, only that it has to increase the size not to click on another without wanting.
(Sorry I'm using Google Translate)
We'll consider adding the Stop All feature in the future. As for tabs, you can try increasing the DPI setting in Windows, it will make all items larger and easier to use with touch screen.
It would be nice to increase the button of the page or to have an option to choose the size that you want, even if you change the DPI configuration of Windows the others will increase also there it is in the same thing or it would not benefit of anything. This option I want has many automation softwares with touch screen, it is faster to turn the pages and play quickly (like the picture I sent up there). I wanted you to think about this a little bit more, it's a good idea.
We may add an option to increase tab sizes in RadioBOSS. I don't think adding buttons to duplicate tabs is a good idea...
screambrs@gmail.com said:
So I want to see this page size option in the future. Thank you :)
Scheduled for the future versions - maybe we'll add it in RadioBOSS 5.6.
