HMMMM
I’ve just finished attempting to add lyrics and synchronize them with the music on my website. It’s a mess, but it has been fun! It all boils down to synchronizing lyrics.
Can anyone create a system that will automatically synchronize lyrics with songs across a large library (like 40,000 songs) using AI and metadata such as ID3 tags? This would involve:
Example:
python
CopyEdit
<span><span>import</span> eyed3<br><br><span>def</span> <span>get_mp3_metadata</span>(<span>mp3_path</span>):<br> audio_file = eyed3.load(mp3_path)<br> title = audio_file.tag.title<br> artist = audio_file.tag.artist<br> album = audio_file.tag.album<br> <span>return</span> title, artist, album<br></span>
Step 2:For fetching lyrics from an API (e.g., Genius API), you can use the song title and artist to search.
Example using requests:
python
CopyEdit
<span><span>import</span> requests<br><br><span>def</span> <span>fetch_lyrics</span>(<span>song_title, artist_name</span>):<br> url = <span>f"https://api.genius.com/search?q=<span>{song_title}</span> <span>{artist_name}</span>"</span><br> headers = {<span>"Authorization"</span>: <span>"Bearer YOUR_ACCESS_TOKEN"</span>}<br> response = requests.get(url, headers=headers)<br> json_data = response.json()<br> song_path = json_data[<span>'response'</span>][<span>'hits'</span>][<span>0</span>][<span>'result'</span>][<span>'url'</span>]<br> lyrics = extract_lyrics_from_url(song_path) <span># You'd have to scrape the lyrics from the song URL</span><br> <span>return</span> lyrics<br></span>
Step 3:For this, you'd need audio analysis. This can be done using libraries like Aubio or a custom deep learning model trained on song lyrics and timings.
A simpler method would involve:
Example:
python
CopyEdit
<span><span>import</span> eyed3<br><br><span>def</span> <span>embed_lyrics_in_mp3</span>(<span>mp3_path, lyrics</span>):<br> audio_file = eyed3.load(mp3_path)<br> frame = audio_file.tag.frame_set(eyed3.id3.frames.USLT)<br> frame.set_text(lyrics) <span># Set the lyrics with timing</span><br> audio_file.tag.save()<br></span>
Step 5:To handle 40,000 songs, you can run the script in batches, processing files in parallel (using multiprocessing or an async approach).
Example:
python
CopyEdit
<span><span>from</span> concurrent.futures <span>import</span> ThreadPoolExecutor<br><br><span>def</span> <span>process_mp3_file</span>(<span>mp3_file</span>):<br> title, artist, album = get_mp3_metadata(mp3_file)<br> lyrics = fetch_lyrics(title, artist)<br> sync_lyrics = synchronize_lyrics(lyrics, mp3_file)<br> embed_lyrics_in_mp3(mp3_file, sync_lyrics)<br><br>mp3_files = [<span>"song1.mp3"</span>, <span>"song2.mp3"</span>, <span>"song3.mp3"</span>]<br><span>with</span> ThreadPoolExecutor() <span>as</span> executor:<br> executor.<span>map</span>(process_mp3_file, mp3_files)<br></span>
- Reading the metadata (ID3 tags) from MP3 files.
- Fetching or generating the lyrics for each song.
- Synchronizing the lyrics with the song’s timeline (timestamps for each line or verse).
- Embedding the lyrics back into the MP3 file with synchronized timing.
Plan Outline for the Project:
This could be broken down into key components, and the tool would be designed to:- Read the MP3 file’s metadata to get song details like artist, album, title, etc. This will help us match the song to its lyrics.
- Use an AI-powered tool or service to fetch lyrics for the given song. You could use databases like Genius API or Musixmatch API to get lyrics based on song metadata. Optionally, a model could be trained to extract lyrics from the song itself if they aren’t available.
- Sync the lyrics to the music: This is the most complex part. You would need to analyze the audio of the song to sync the lyrics with the music. Using audio analysis tools (like SonicAPI, Aubio, or machine learning models) to identify when specific words or phrases are sung would work. These timestamps would need to be calibrated to match the flow of the song accurately.
- Embed the lyrics into the MP3: After synchronizing the lyrics, we need to embed them back into the MP3 file using the ID3 tags (specifically the USLT (Unsynchronized Lyrics) frame for lyrics, or if using LRC format, embed that too).
- Batch processing for efficiency: The program will need to handle batch processing efficiently to process thousands of songs at once. You could run it in parallel for multiple files to speed up the process.
Key Steps in More Detail:
Step 1:Use a Python library like eyed3 or tinytag to extract MP3 file metadata.Example:
python
CopyEdit
python
CopyEdit
- Audio segmentation to identify the tempo and beats.
- Speech-to-text or lyric recognition tools to detect the timing of lyrics.For more precision, consider using an existing deep learning model or a tool like SonicAPI, which can generate timestamps for lyrics.
Example:
python
CopyEdit
Example:
python
CopyEdit
Challenges and Considerations:
- Accuracy of Lyrics Sync: Automatically syncing lyrics is quite challenging, especially with songs that have fast lyrics or varying tempos. Using pre-trained models for speech recognition or music-specific analysis would help, but it may require fine-tuning.
- Handling Missing Lyrics: Not every song will have available lyrics through APIs. A fallback method could involve generating approximate timing based on audio features.
- Performance: Processing 40,000 songs requires optimization. Ensure you’re handling memory usage, concurrency, and large file sizes effectively.
Tools/Libraries to Consider:
- eyed3: For reading/writing ID3 tags.
- requests: For interacting with external lyric APIs.
- Aubio: For audio analysis and tempo detection.
- SonicAPI or Google Speech-to-Text: For more advanced audio-to-lyrics synchronization.
- multiprocessing: For parallel processing.
