Playlist Generator Pro / Schedule
exposureir
Just got a good idea!
Is there any way to make it so you can schedule a playlist to be generated (like in Playlist Generator Pro) but at a certain time (like midnight) then add the playlist to the player like in the Scheduler?
For example I would have two m3u playlists, rap.m3u and rock.m3u, then I would be able to generate a playlist (being able to not play artists/tracks for x hours/minutes like in Playlist Generator Pro) then RadioBOSS would add that to the player and play the rap at midnight each night, then at 3am it would do the same thing for the rock playlist and play it until midnight or whatever.
I hope this makes sense? lol
Also, in the Playlist Generator Pro can you make it so you can play a track before the playlist starts, for example I want to play a jingle that says "This is the Exposure midnight rap mix" or something like that, so it would be nice to have it play that, then play the playlist.
Also, in the Playlist Generator Pro can you not do Jingles?
In the next update it will be possible to generate playlists using Playlist Generator Pro by schedule.
About starting jingle... I think we'll add an option to the category like "insert only once" - so, to insert the "opening" jingle, you'll need to create a separate category for it and insert it first in the "Playlist structure".
Okay awesome!
Okay that sounds like it would work well,  but what about placing a jingle after x number of songs like you can in the original playlist generator?
This feature will be added too, but in later versions.
