Playlist type sets equalizer
Lets say a radio station has different music playlists:
  • Pop at 13:00
  • Classic at 18:00 etc.
Is there an option to mark playlist as Pop or Classical, or Rock and when that playlist is loaded the type of the playlist trigger an equalizer setter? Some music playlist to activate "Party" in equalizer or "dance" or  "Classic".
If makes sense would be that possible?
Yes, it will be possible using the scheduler command to change the EQ preset. You can then use the "Multiple actions" scheduled event (or use separate events) to change the current EQ preset.
