[Web site] Show current track title, cover art, recent tracks
Please inspect your server logs for the details on this error.
It was slow server, solved. But I have another question, how do I add the next song option? It's not very clear how to make this option appear. I am grateful if you can answer me.
Hello, at the beginning, I'll apologize for the spelling, because it's a translator, but to the point, namely after updating to a newer version, namely RadioBOSS v6.2.2.0 x64, it stopped sending covers to the server, when I go back to the older version of RadioBOSS v6.1.0.5 x32 everything works fine, my question is what could be causing this and how can i fix it. Best regards and thank you in advance for your help.
How do you send cover art, do you use HTTP requests? Does it show any error messages?
Hello, no error, just the boss does not replace the png file, I wrote earlier that everything works fine in the older version, I did not change the www code and those who have an older version only work for those who have the new one
Please ensure that saving artwork is enabled: https://manual.djsoft.net/radioboss/en/log_files___reports.htm - the "Save artwork" must be checked and file name is specified (the default is \artwork.png meaning it will save this file to the settings folder.
Then, please click Settings->Open Settings Folder and check if this artwork.png file is properly updated.
Hello, sorry for the confusion after updating to the RadioBOSS.6.2.2.0 version, the option in the reports, the track title played after putting x there, everything works again, sorry and best regards.
