RadioBOSS 7.0 [beta]
I have a Problem after installing Radioboss 7.0.0.6 32 Bit
Same problem after a clean install Radioboss 7.0.0.6 32 Bit
Report:
23:08:59;system;Started;
23:09:06;error;"Access violation at address 00D6EF1D in module 'radioboss.exe'. Read of address 000000FC.";
23:09:06;error;"Program will be restarted because of fatal error.";
23:09:21;system;Started;
23:09:29;error;"Access violation at address 00D6EF1D in module 'radioboss.exe'. Read of address 000000FC.";
23:09:29;error;"Program will be restarted because of fatal error.";
23:09:42;system;Started;
23:09:50;error;"Access violation at address 00D6EF1D in module 'radioboss.exe'. Read of address 000000FC.";
23:09:50;error;"Program will be restarted because of fatal error.";
23:10:04;system;Started;
23:10:12;error;"Access violation at address 00D6EF1D in module 'radioboss.exe'. Read of address 000000FC.";
23:10:12;error;"Program will be restarted because of fatal error.";
23:10:26;system;Started;
23:10:34;error;"Access violation at address 00D6EF1D in module 'radioboss.exe'. Read of address 000000FC.";
23:10:34;error;"Program will be restarted because of fatal error.";
23:10:35;system;Exit;
Report:
update
I had to uninstall my Mc Afee virus software because McAfee Framework Host Service could not be stopped
I then installed the RB 7.0.0.6 32bit and had no more problems
Mc Afee installed again and everything was fine
It does not save the fields I mark in the tag (track tools).
The option to hide the progress bar would be nice.
There is an incorrect (and extra) "darkslategrey" color in the color options.
Font options such as bold, thin, italic... are not functional.
update
It is not the antivirus. It keeps happening to me
Opens and closes on its own indefinitely
Even restarting the system does not allow me to access the program
I tried to reinstall but I keep getting errors
To nie jest program antywirusowy. Ciągle mi się to zdarza
Otwiera się i zamyka samoczynnie w nieskończoność
Nawet ponowne uruchomienie systemu nie pozwala mi na dostęp do programu
Próbowałem zainstalować ponownie, ale ciągle wyskakują błędy
It's even more interesting for me.
(RadioBOSS 7.00.6x64)
The safe program runs until the last item in the playlist runs.
closed, it starts closing and opening nonstop.
I checked several playlists of different lengths and it always happens, until the last element, that it is not a music file but, for example, the Disconnect command.
you're right. I have a "comment" command at the end of each list to indicate the end of the playlist and that happens. I think that causes the error
Report:
Having the same problem only the access violation shows a different address.
Access violation at address 00000000011887F6 in module 'radioboss.exe'. Read of address 0000000000000184.
I also confirm that the program resets when changing songs or any changes made while a song is playing.
This error appears in a trial version of RB in Windows 10, but in a registered version of RB in Server 2016 it works perfectly!
I tested in a registered RB in Windows 10, and also the error persist....
It seems that it is an error for when there are no files to be played, I tried placing a single file in the playlist and this error occurs.
Deleting everything in the playlist and you will get this error.
I think a couple of other people have mentioned it but we're seeing it too.
Right click > Delete all. The items delete momentarily, the software closes and reopens, the playlist re-appears as it was.
I have a problem as seen in the log. But when sending an error report it says what is in the image.
The program closes and opens automatically
Thank you. We received some of the similar bug report files, this will be fixed in the next update. I'm sorry for the inconvenience.
This is interesting. Did McAfee show any warnings/detections when you were installing or running RadioBOSS?
Those fields are not supported for every file format, what file were editing?
Can you please specify where this progress bar is?
Can you please specify where this is located?
And for those too, please.
No McAfee did NOT show any Warnings
The first time I installed RadioBOSS 7.0.0.6 I chose to close it automatically and nothing happened it diddnt close Mc Afee Framework Host automatically.
The second time I chose not to close the application, the setup continued with the result that the radioboss constantly opened and closed again.
I uninstalled Mc Afee completely, then installed RadioBOSS 7.0.0.6 over the broken installation and everything was back to normal.
Reinstalled Mc Afee and everything remained as it should be
