Programmed shows repeating by themselves
RadioTeAroha
Help! Please see attached screenshot about what we've logged with RadioBoss as a problem. Sometimes scheduled shows repeat themselves at odd times without them being scheduled to do so. As an example, a scheduled show which was set to play last night at 9.30pm did so perfectly but then somehow the system decided to play it again at 8.34am this morning. Has anyone else had this problem and have any idea on how to fix this?
Looks like the event remained in the playlist for some reason (e.g. another event started that interrupted it). You can check the Logs section to see what events started when. You should also check other events that may start the same music/shows to see if the repeat comes from there.
There were no events scheduled for the time when the show repeated itself. I still have no fix for this problem.
You should inspect the Logs to see what started and when, also observe the Overview section, see what happens (what is added/removed, what is playing) in the playlist window. From our side, we can guarantee you that events only run when they are supposed to and never run outside of their scheduled time.
