additions for Dj broadcasting
unex
Your software works so far with one deck. Can you please add the following features:
- integrate a second deck
- Cross fade between two tracks
- Automatic beat detection
- Synchronization between the decks
- the possibility to adjust the bpm manually for each deck
- Real-time pitch and tempo control
- Apply effects in real time
The features are needed for Dj's  at webradios.
I think there is a big difference between software radio and DJ.
are aimed at completely different markets.
It would be good desert that incorporate more players. but two major players, auxiliary prefer, I like having a single list.
but I would like the features you named as:
  Automatic beat detection, Synchronization Between the decks, The Possibility to adjust the BPM manually, pitch and tempo control, are implemented directly in Follow Editor.
eg ProppFrexx radio automation software, has these characteristics.
unex, thanks for suggestions.
* AUX players are under development now, and will be added to the program soon, I think we'll start with 2 AUX players... or maybe 4.
* Crossfading is already there - automatic and manual. For manual you can use segue editor, automatic can be set up here: http://manual.djsoft.net/radioboss/en/crossfades.htm
* Beat detection and other DJ functions are not a priority now... There are Pitch and tempo controls in the FX tab: http://manual.djsoft.net/radioboss/en/fx.htm
oh, sorry. :-[  it announced in its characteristics. I installed the demo of this software recently, and I thought it was me who had not yet been able to understand.
You (the general you) know a software is bad when they have a built in mixer, in that way, inside of there software. You never put a mixer like that in a software. Sorry for the harsh words.
