several issues
Hello Dmitry.
A suggestion:
When I'm editing metadata of a song in another playlist (other than air) and ends the current track, the editing of metadata is lost and must be re-typing.
Would it be possible to change this behavior?
Thank you
Do you mean that when it goes to the next song, it updates the tag editor window with the new song info?
No. The situation is as follows:
Sometimes I find myself editing matadatos a list of auxiliary reproduction (playing music RadioBOSS to another playlist). But once the track that is in the air, the metadata changes that were not saved are lost.
I think that an image can help.
This bug was not confirmed. What RadioBOSS version do you use?
I'm using the 5.3.0.0 version.
We do not buy the upgrade but I thought the error was still in newer versions.
You don't need to buy an update in order to use the latest version (please let me know if it does not accept the key) - I'd suggest you to use the latest RadioBOSS version.
just I try in another pc using the latest demo version and the error is not there. :)
So is. I can not use the latest version.
If you need to send him an email with my license code.
It's not accepting your code? If this is the case, please write to support@djsoft.net we'll fix your code shortly.
Yes, does not accept the code.
I just sent an email.
(Sorry also send it to sales@djsoft.net earlier in error)
Dmitry had a problem when entering the code.
I sent an email about it.
I am using the demo version on the PC main transmission.
Thank you
Dmitry is a problem with the bar Intro.
sometimes it not is shown and sometimes works well.
It's strange.
Do you use the latest version? There were some fixes about it in RB 5.3.3.1.
It's strange.
That's right, I'm using that version.
I remember you once told me in an earlier version of the program that restarting the program solved but this happens very often.
When it stops showin, does it mean that it never shows the Intro again until it is restarted?
Another small problem.
When I have enabled the option "Highlight duplicate tracks" and delete a song from the list, the program hangs seconds. (list of 4500 songs)
It would also help an option "delete duplicate tracks"
After restart works well
This is very common.
OK, I've added it to the list of bugs.
Yes, depending on your computer CPU power, re-checking for duplicates can take some time... The "delete duplicate" option can be dangerous, e.g. it may delete all jingles and station ID's as they are usually repeated throughout the playlist.
If that is true, but on the other hand is very useful for editing playlists.
(I use this function in auxiliary "tab list", not tab air)
Perhaps a confirmation question could avoid this?
There is so annoying remove duplicate tracks. (It is even faster to perform)
The problem is that in 4500 lists the program freezes songs several seconds (with a core i3).
for each track you remove the program is five seconds frozen.
These freezes are bothersome, so I thought this characteristic.
