several issues
-Bug In 5.2.3: Sometimes the RB tag editor does not write the letters are pressed, you have to push twice the same letter to be written, this is very annoying. I think the problem is when it is typed faster. in the previous version of the program, this error does not exist.
Did you install any other programs recently? There were no changes regarding this in the latest RadioBOSS release. The only thing why it could be affected is hot key processing, but IIRC it wasn't changed neither. If you type in other edit boxes in RB, do you see the same bug?
Do not install any other software.
The problem only exists in the table metadata editing,
for example the field of search works perfectly.
Maybe it is weird problem that is solved with restart RadioBOSS.
Tonight I will Reboot the pc and will notice if it happens again.
-You can add "Maximum time waiting in queue to play" in ADS scheduler?
This is already the planner implenetado RB, so do not think it is very laborious.
Yes, this is planned for RadioBOSS 5.3.
Ok, thank you very much.
Does it happen with a particular field in metadata editor, or it happens with all fields?
The last version doesn't show the sound waves of the played file if it's bigger than 15 minutes or so.
The sound bars are working though.
Yes. This is by design, to avoid high memory consumption.
Hello Dmirtry:
Recently found a problem that causes crashes hard radioboss and restarted:
When trying to generate a list of the Playlist Generator Pro from the developer of events and the preset contains only tracks from a playlist file. if all the tracks of the playlist were moved around, and therefore do not exist RB restarts.
Are there any error messages in the log or bugreport files (Settings->Open settings folder)?
There is nothing there.
I think it was by a failure of the hard drive, which causes it to hang.
We had changed this hard drive last year.  :(
Let me know it it happens again... We can't reproduce it here.
Hello Dmitry.
Today a power cut made disaster in the RadioBOSS configuration.
The disc has disabled the option "Cache to increase speed", to avoid this problem, and yet this didn't work.
Can you improve this?. I have attached the profile files and error reports
Also would be good thing to "Freeze the configuration of RadioBOSS" or set the profile as "Read-only" so that these things do not happen.
This instance that failed only is used to play streaming, but it has a lot of settings that are never modified (or rarely).
So have frozen profile would be very stable.
I today learned that the FM radio was off the air 4 hours after the problem by a call from a listener.
Good point !
The correct way to solve this problem is to eliminate power outages in the first place. Use UPS, it will keep the computer up for 20-30 minutes and correctly shut it down in case there's still no power (you'll need UPS which connects to PC via USB). UPS is a must have for any PC, especially ones which used for broadcasting.
RadioBOSS already creates one backup copy of each settings file. In your case it seems both copies were damaged... It's nothing more RB can do apart from making backup copies, and it already does so.
Also, from bug reports I see that you're using the previous version (5.2.0.10) - I'd suggest you to install the latest one (5.2.3) as it contains lots of various fixes and improvements.
This can be frustrating, with frozen settings you'll be unable to change anything, even some minor setting (e.g. window position and size, etc).
What you offer is fighting with symptoms, but fighting a cause (power outages) is way more effective and reliable.
You can "freeze" settings like this: set everything up as needed and create a backup copy. Then, if something goes wrong, you can simply restore from that backup.
You can also try "freezing" if you play with settings folder access rights (you can make it effectively read-only for RB). I'm not sure, however, how RB will behave under those circumstances, probably you'll see lots of "unable to write to..." error messages.
I am aware that the ultimate solution is a UPS, but at this time it is not possible for the economic factor.
At this time we have on the one hand the studios of radio station, RadioBOSS is where used for the emission to air, which it is important to be able to save the settings. and in transmitting plant there is another PC with RB that only receives streaming.(which virtually never anything is changed, even the position of the window is what you want to freeze.) Screenshot attached.
At the moment we're saving to install other two FM transmitting stations in different cities in the which initially there will not be a person intended to control all the time that everything is working well.
We have the need to install everything as soon as possible, so at first nor will there be UPS.
These PC configuration, will be the same as we have in the transmitting plant of the unique frequency that we have in the air at the moment.
So if this problem happened here, also it could be repeated in any of the other transmitting plants installed, and we want to minimize the likelihood of these problems.
You're right about this.
On the backing of the profile, is really a feature very useful.
The problem is that if a profile is damaged, RadioBOSS does not load the profile from the backup automatically, this was what caused the cut from 4 pm. (I was advised by a listener that the radio was the silence)
Perhaps with the feature "When unable to load profile, restore the BackUp configuration..." would be good.
Anyway you have reason above that the problem itself is not caused by RadioBOSS.
If we can make work RadioBOSS with a read-only profile, this would be the ultimate solution to the problem, already profile not to break ever. :)
I'll try then as RadioBOSS behaves with a read-only profile. I'm going to disable logs (that do not use for anything), and the "CurrentSong.txt" file will be moved to my documents.
Not opened any problem to RadioBOSS alert that there are problems of writing (except that this generates a high CPU usage).
I'll know if it works then.
Yes, without UPS it's impossible to build anything reliable enough. I'm afraid RadioBOSS will not ever be designed to operate in such conditions (power outages and following data corruption). It makes one backup copy, just in case, but that's it.
You can try making the following files
- player.ini
- system.ini
- profile (*.prf)
read-only using Windows access rights (right click on a file->Properties->Security).
It will "fix" the configuration.
Please consider UPS as a mandatory hardware requirement when a PC is used in a commercial environment. Like CPU or RAM. Without it the system is unreliable.
Well, this is again fighting with symptoms, and is totally ineffective. The next step would be "if backup file is damaged too, restore from another backup" and so on :)
A test fast with permissions, it worked great.
Only that the posters of errors are annoying especially when you need to restart the PC. (PC not turn off to accept all warnings)
Yes, that's a downside of this method. You can create a .bat file which performs forced shutdown (using the "shutdown" command). Or, you can try using the poweroff command in RadioBOSS scheduler, it should also perform a no-question-asked shutdown.
Hello Dmitry.
Two things I found:
-The option to start only with DTMF event does not work in the way that the manual says.
by testing I did it works only if it is hours and plays the DTMF.
In the manual it says that only plays when it detected the DTMF tone (ignoring the scheduled date)
-There's a problem editing metadata of wma files.
To edit this metadata, the file becomes corrupt and cannot be played.
I have attached a file
Starting with RadioBOSS 5.2 it doesn't ignore the start date/time anymore. It's an error in user manual.
Thanks for the file, we'll check what could be wrong there.
It disappears when you use the User Account Control and disable playlist sorting. Is it the case?
