xzsaimon16
There is a problem with the time announcement bed, it is not playing.
Automatic updating is not working for beta versions.were is It's fixed in RB 7.1.0.1, please update. did i miss it? its not updated in software
This is a bug, it will be fixed in the next update.For some strange reason sometimes TimeStreach doesn't start when I open the program.
I set extreme values and I still don't see it start
And this is a bug too, thank you, will be fixed.TimeStretch calculates a next track adjustment for the next hour, this is not correct
Yes, it will work. Two SALSA tracks will not be inserted one after another.1) I want to ask, is this configuration you establish correct? Would it work?
This so that the same gender is not placed twice
Thank you, noted for the future updates.2) A suggestion, I would like the list of all the genres that were established in the music library to be displayed. This in Constraints and additional separation rules.
A command will be added to turn time stretch on/off, thank you for the suggestion.And if I could turn this feature on and off from an event in the playlist? so that it only adjusts the last 15 minutes (where nothing will break into the current list)
I'm sorry for this, the license number was corrected. During beta, the upgrading mechanism is simplified so mistakes like this are possible.Hello, Dmitry. I bought an upgrade tonight from advanced to ultimate for three of my licenses. However, now that I log in to customer area it says I have six licenses. What happened there? I just installed a new version. I haven't started testing yet.
Yes, if certain dynamic items are present in the playlist, exact playlist duration/track start time calculation is not possible, because duration of those items is unknown until they start playing. I'm not sure of the solution for this. Maybe preloading those items somehow, but sometimes it wouldn't be possible because some items depend on playlist contents and this may change.I think in Radioboss it is impossible to accurately calculate the duration of the playlist. What for me, for example, extends the list are teasers, radio id jingles, TTS announcements. If all this could somehow fit into the duration of the playlist then it would be quite accurate with those actions on the topic that Dmitry linked here.
Please check if you have any DSP plugins enabled. Maybe one of them is doing this. If this continues to happen, please start a track, wait for it to fade out and press Ctrl+F4 to show debug window, then send us a screenshot of RadioBOSS and this debug window.Found a bug with this version when playing anything, the volume goes down at the beginning, like a fade in, but all crossfades are deactivated and haven't changed the presets. The song is with a low volume when ress play.
How often does it happen in your case? For every track or only occasional?I have also observed this.
I think this would be possible to add, maybe even during this beta.Of course, this would not apply to the Priorities, but only to the ads within the same Priority. This would be a big step for customer satisfaction. For now, I do this manually quite often.
Can you please send screenshots of Track Tool configuration for the music? And how long is the voice track?I’m still noticing an issue with the voice tracks.
On all my tracks, I’ve set mix points, outro, and intro points.
The voice track starts at the end of the song's intro.
To be more specific, I place a voice track between two songs. The songs transition from one to the other. I have the countdown for the intro on the song, and at the end of the intro, the voice track starts.
Do you only need it for Played tracks or also for nowplaying/next track?Will there be an option to alternate priorities in the future?
For this feature, it doesn't matter how the tracks got into the playlist. The feature will calculate when the next hour starts and then stretch/squeeze tracks to end them at hour end.Hello, I am testing the Time Stretching feature. I enabled it using the default settings. Can someone tell me how it should work if a playlist is generated and added?
How did you configure the bed, is it in file type configuration?There is a problem with the time announcement bed, it is not playing.
For played tracks only, the rest works as expected.Do you only need it for Played tracks or also for nowplaying/next track?
Yes, file typeHow did you configure the bed, is it in file type configuration?
Start Time is not calculated in certain cases, e.g. when playlist is in Shuffle mode.Not seeing start times in the playlists.
OK, we'll see what can be done about it.For played tracks only, the rest works as expected.
Thank you, we'll check it.Yes, file type
Looks like you have entered a beta tester key, which is for the Ultimate version, and the older versions do not handle this properly. You can re-enter your Advanced key to return to this edition. Currently you can't have both Ultimate and Advanced keys installed under the same Windows user.Tonight after the relaunch of version 7.0.8, I was greeted with a notification that it was the express version, not the advanced.
The title should be shown in the Broadcast Title column, please check if it's there.When inserting the teaser from the PL generator it does not show the established broadcast title. It always shows the title of the next screenshot
It's the same. It appears if I add it from the insert teaser option in PL. But not from the PL generator.The title should be shown in the Broadcast Title column, please check if it's there.
The Playlist Generator doesn't support streaming titles, I'll add this as a bug.It's the same. It appears if I add it from the insert teaser option in PL. But not from the PL generator.
Please call it as follows:/?pass=password
Thank you, we'll check it.I have discovered a bug in the Remote Voice Tracking module. It seems that the VST bridge is missing. When trying to load a VST plugin, an error message appears.
