RadioBOSS 7.1 [beta]
the error was due to the command in the sheduler because the on after streamarchive is obligatory
the defaults for date and time %hh %nn %ss - %d %m %y are not recognized, an incorrect que file is created
No error messages
If you run it from the scheduler and want to create backups based on current date/time, you should use the scheduler's template variable like ?hh, ?dd and others: https://manual.djsoft.net/radioboss/en/scheduler_options.htm
The file name template variables %hh and others work only in the stream archive itself (in its configuration window), not for the command.
Remote VT 1.0.0.3
Changes
  • Shows the current and next track titles
  • Shows the playing track position and remaining time
  • Added confirmation for delete track command
https://dl.djsoft.net/beta/RemoteVT_setup_1.0.0.3.exe (3/12/2025, 7MB)
It would be very convenient if, in the new panels, clicking on the "on air" and "next" panels would select songs from the playlist. (As RadioBOSS does)
It's also useful to have file types displayed (paint them in the playlist), although I imagine that requires more work than the first one mentioned.
Noted for the future versions, thank you!
I'm experiencing a bug with version 7.1.0.5 beta related to teasers. The playlist freezes after playing a teaser. The teaser starts correctly with a preview of the next song, but when it's time to play the full track, the playlist stops.
This issue occurs especially when time stretching is enabled and when voice tracks have been previously inserted,. (See the video for more details.)
Additionally, a small request: it would be very useful to have a column displaying the intro duration in the Remote Voice Track. This would help in managing speaking time more effectively.
Thanks for your help.
I'm experiencing the same bug with version 7.1.0.5 beta related to teasers. The playlist freezes after playing a teaser. The teaser starts correctly with a preview of the next song, but when it's time to play the full track, the playlist stops.
As a result, the entire Radioboss freezes and disconnects from the stream
In general, this version often freezes and is then automatically restarted, which is absolutely unacceptable when you are on air
How are you running a teaser, Patrick I havent noticed this in 7.1.05; my things are back working. I think I didnt notice i had moved some random voiceovers to another directory and my file types was not picking them up lol. Oh hang on last week it would not always runn the new random playlist i have
after a new clean installation no problems anymore
Patrick That's what I had in the previous version; it would play the teaser from random grabbing teaser tracks and through the foating palette by overlay playback and lockup. But 7.1.0.5 beta solved it. I had some oddities just now; the broadcasting music turned off for no reason and didn't notify me. This really needs to be in red in the log if possible, Dimtri. Otherwise, everything was ok. Even my lyrics got spat out without crashing so that was a good start I need to rewrite my ParseJonsonLyrics next week as it's too complicated and is failing. The site cannot cope with it even though everything in the code is OK, so I'm going to simplify it. I am using the lyric route as much as I can, but they is not easy to find It's hard enough to get two hours with all the lyrics still, so it's all in its infancy, I guess. I dont think it updates the main random driver ptemp playlist after its finished, or if it does, it leaves the playlist empty. I am not sure why if you press refresh, it comes back.
Hugs D
The option to remove MixStart points in MusicLibrary doesn't work. (Recalculate again)
I want to remove these points, but I can't find a way, except for a query in the database, but I shouldn't.
Thank you, we'll check this.
Noted for the future updates.
Do you also use the Time Stretch feature?
Does it freeze when playing teasers, or it also freezes in other cases as well? Are there any bug reports that can be sent from the Help->Contact Support menu?
You should check the Log area to see if there were any error messages.
Still this is not normal. Probably some option (Time stretch?) had caused it.
I'm not sure it can stop playback by itself. Maybe the track had just ended?
Thank you, we'll check it.
UPDATE - The stretch feature seems accurate now.
That's good to know!
also in other cases to but after a clean install 7.1.0.5 no problems anymore
Is there a way to create a timestreach log?
Mainly to see what I'm trying to do and if it's successful.
Because the setting I applied is "erased" from the list with each replay.
It would be interesting to have the sigue editor as a tab in the workspaces, so you can make changes without opening a new window.
It will be added as an advanced option.
The problem with the Segue Editor is that it requires many resources to operate, and also needs a lot of screen space. So I'm not sure how it'll look in a work zone.
RadioBOSS 7.1.0.6 beta
Changes
  • Ads Scheduler: automatically resolves ads type conflicts where possible
  • Playlist: added Gender column
  • Segue Editor: takes into account parameters set in Track Tool when tracks are first edited
  • Fixed outro display bug when a track was edited with Track Tool during playback
  • Time Stretch: added logging (Advanced Settings, Logging - Main Player log)
  • Fixed possible deadlock/freeze bugs
  • Fixed minor UI issues in various windows
  • Process Tracks in Music Library: fixed "Remove" options did not work sometimes
  • Fixed librray search when search string contained certain special characters
  • Fixed: notification test did not work for some notifications when they were turned off
  • Fixed: custom artwork for scheduled events was not saved
  • Other bugs fixed
x86 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.6.exe (3/21/2025, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.6_x64.exe (3/21/2025, 38MB)
Changes
  • Other bugs fixed
Hi, could you explain how this works?
I note a slow process now when you make changes
When it detects two ads of the same type (one after another), but with a different priority, it will move ads (with the same priority) so that ads of the same type do not follow each other. This requires additional processing, that's why it can slow things a bit. But it results in better quality of the ad blocks.
