RadioBOSS 7.1 [beta]
Even though I get a "PlGen Error: 1 (errors while creating a playlist)" Now having examined the log files, in my case the event successfully generates the playlist (it creates a temp file in the AppData folder) but does not load it automatically for it to play as it should. And this applies only to presents I created/modified with the previous update. The log file shows that all the songs were loaded. For older presets there is no problem. The newer presets can't be generated as a scheduled event. This looks like a bug. Could you please kindly give it another look?
So just now I decided to reinstall an old copy of version 7.0.5 I had, and guess what - the problem disappears! All events launching and generating playlists as normal! Something must have gotten tweaked in the new version that is causing this problem.
When you switch within track f.e. from minute 1 to 2 (in green box) the song slowly is fading in again instead of continuing playing. That's not normal ... so I won't install newest version for productive stream.
Thank you for the information, we'll check it again.
It worked like this for years, since 6.3 if I'm not mistaken. A small fade is applied on seeking, so that it's not abrupt. It wasn't changed in this version.
Hi Dmitry. We have several hosts who might like to use the Remote Voice Tracking. I see that it is a module. I assume that it is something you install on the remote computer. Can it be installed on several computers? What happens if two people try to use it at the same time?
You can install it on any number of computers, and simultaneous use is also possible. However, this should be done with care as conflicts are possible if two users edit the playlist intensively.
