radiodungog
Hello Dmitry,
Yesterday I renewed our licence keys for RadioBOSS, RadioLogger and RadioCaster.
Both the RadioLogger and RadioCaster updates have been done and are working correctly.
The RadioBOSS update was 99% successful but has left us with three problems:
1. The regular tab player screen is all over the place - meaning the columns are nothing like they were before. I have altered the columns as best I can but I cannot remember exactly what they layout was before. I would have thought those settings would have been preserved from the previous version. Is this the case ?
2. The regular tab player has weird looking icons for Prelisten, Play and Delete. I cannot find where to adjust them. Any ideas ?
3. On the regular tab player the Search tab and search box on the right is empty and does not show any music search results. I cannot see where the music library search database is located so I cannot fix it. We are unable to select music and put it to air.
Here is an update:
4. After 4 hours I can see a problem.
On older versions (5.9.4.0) > Settings > Options > General window at the bottom has:
Music Library folder: \Database\
Voice Track folder: \VoiceTracks\
On this current version (6.0.6.2) > Settings > Options > General window at the bottom only has:
Voice Track folder \VoiceTracks\
No box for the music database. Could that be the trouble ?
Can you give me any ideas ?
Thanks, Jamie C.
Radio Dungog
Here is an update:
Thanks, Jamie C.
Radio Dungog
