tomimatko
xzsaimon16
There is a problem, it does not generate the playlist that is programmed. I hit the manual option and it doesn't generate the playlist either.
Same case for me. The scheduler doesn’t generate a playlist, meaning it doesn’t add any songs. In the Playlist Generator, when I press "Generate" it shows that everything is OK, and when I click below on "Export to Player", the songs appear correctly in the playlist.
The settings are the same in RadioBoss 7.0, and everything works fine there, but not in this test version.
